| Home > Help Needed / General Tech Chat > Clutch Bother | |||||||
166 Posts Member #: 221 Advanced Member |
28th Jun, 2004 at 09:59:10am
Have been flat out working on the mini for NIMW, however after fitting a new verto clutch and bolting everything back in and bleeding the clutch, it feels as hard as a rock with very little travel. |
28th Jun, 2004 at 11:45:25am
Anyone got n e ideas???I have to get the car out of the garage asap as the house is now sold.
28th Jun, 2004 at 01:49:59pm
Sounds like the clutch is adjusted wrongly, especially if it stalling the engine, you will need to set the nuts on the end of the "wok".
28th Jun, 2004 at 02:07:55pm
loosen them both off then wind the one in nearest the housing to leave a 6mm gap. then lock it up with the back nut. |
28th Jun, 2004 at 03:19:07pm
Thanks guys
28th Jun, 2004 at 04:04:12pm
I can't see thoes nuts being to tight would cause the engine to stop.
29th Jun, 2004 at 11:16:32am
Loosened the nuts off to 6.25 mm, they were very tight.
29th Jun, 2004 at 11:45:55am
I had the same problem last week. havent solved it yet as when i removed the clutch for inspection the crank taper was damaged so ive got that to replace.
30th Jun, 2004 at 12:01:11pm
Ok got the wok bolts set and the clutch bled, and the clutch pedal has now got some movement at last. Still does'nt feel right and may need some more fine tuning. Still a bit tight getting gears (the odd crunch)
30th Jun, 2004 at 12:20:03pm
I still reckon it could be the release bearing.
6th Jul, 2004 at 11:28:54am
Thanks guys for the help, but in the end i just got to tired and fed up working with the mini.
