| Home > Help Needed / General Tech Chat > engine fitting help | |||||||
![]() 213 Posts Member #: 249 Senior Member |
28th Jun, 2004 at 11:55:55am
sorry but there may be a lot of questions this week as im on holiday and working on mini all week.....im rebuilding my engine up this week and was wondering if its better to refit in car with head off or as a complete unit...i was thinking it may not be possible to put head on with turbo unit on with the block installed because of clearance problems...any feedback appreciated |
28th Jun, 2004 at 11:59:09am
I usually fit the whole lump assembled. it can be done out of car though, check out the pics of Jon replacing his head gasket in the car park at the RR |
28th Jun, 2004 at 12:01:31pm
Hmmm, following that experience, My recomendation is to build the lot up on the workbench / garage floor (but without the starter or dizzy (or just remove the dizzy cap and rotor) and drop the lot in in one!
Edited by turbodave16v on 28th Jun, 2004. On 17th Nov, 2014 Tom Fenton said:
28th Jun, 2004 at 12:04:38pm
Has to be said it didnt look much fun!
126 Posts Member #: 244 Advanced Member |
29th Jun, 2004 at 06:53:06pm
managed by myself to install the turbo engine already in the subframe with running gear in to a non-flip front from underneath - it isn't that difficult. The only help I had was a small ?20 trolley jack! I did find out part way through that you HAD to remove the alternator, starter and dizzy cap to rock the engine forward enough for the turbo to clear. Speedster turbo under construction |
421 Posts Member #: 245 Senior Member |
29th Jun, 2004 at 09:51:38pm
just fitted my sons engine went in complete
![]() 826 Posts Member #: 247 Post Whore Kent/Surrey Borders |
30th Jun, 2004 at 10:08:22am
put my fully assembled engine in with the following items removed
TurboLessTosser |
30th Jun, 2004 at 10:49:09am
i left the starter on and everything else, apart from the altenator which i looseneed and tucked in, and had to take the dizzy cap off. Only thing to be carefull of that i found was that when jacking it up to manoover it in place, i almost bent my scuttle pannel jacking the plenum up into it! Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
102 Posts Member #: 155 Advanced Member |
30th Jun, 2004 at 10:53:04am
do you need to remove the brake servo to take the motor out, is there enough clearance? |
30th Jun, 2004 at 11:23:53am
you can do it, i managed it. just need to tilt the engine and rock it about as its coming out. On 20th Oct, 2015 Tom Fenton said:
30th Jun, 2004 at 02:07:42pm
nice one cheers ! BUD666 |
30th Jun, 2004 at 02:27:09pm
front subframe with engine will fall straight out the bottom with the servo still fitted, but you will need to disconnect the front brake pipe from the reduction valve to the O/S brake connection. Speedster turbo under construction |
1st Jul, 2004 at 10:55:03pm
if you do it out the top though then there's no need to bleed the brakes after. i hate bleeding brakes fiddly annoying nipple breaking job. On 20th Oct, 2015 Tom Fenton said:
1st Jul, 2004 at 11:51:52pm
i pulled the servo appart ; you can remove the middle part ; the big disc shaped thingy
TurboLessTosser |
244 Posts Member #: 34 Senior Member |
2nd Jul, 2004 at 10:21:27am
Install fully assembled.
2nd Jul, 2004 at 11:45:42am
Its easy getting that on as long as you leave the steadies off while fitting it |
