| Home > Help Needed / General Tech Chat > whats my engine?????? | |||||||
20 Posts Member #: 2127 Member |
4th Dec, 2007 at 11:40:17pm
hi just stripped an 12h engine i had laying around. to build a turbo motor, the head is 12g 940. but i cant figure out what the engine is. the number is 12hco1aa 114253. and on the top of the dished pistons is, a 21268 g7L18. can anybody help me as i need to know if this is a good basis for a budget build. thanks. |
141 Posts Member #: 954 Advanced Member Fort Collins Colorado USA |
5th Dec, 2007 at 06:00:38am
I have the same engine code. I've found one source saying 9.75:1 compression 63HP, and another 8.8:1 compression 55HP.
1275 with Back Door Turbo |
5th Dec, 2007 at 03:49:26pm
One more thing: Mine runs fine with 8psi boost on 95 RON gas. So I'm thinking it is the 8.8:1.
5th Dec, 2007 at 04:35:58pm
Found this on Mini Forum spreadsheet:
5th Dec, 2007 at 08:54:02pm
A 12HC01 is a standard compression ratio 1275 (9.4:1) originally fitted to a 1985 -1987 Metro. |
5th Dec, 2007 at 10:29:28pm
thanks for all the help so far this is a great info source. im new to the turbo game. is the 9.4:1 cr to high to run decent boost. and the othe question is the 12g940 head has been skimmed on the top surface. anyone know of a reason for this. |
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
5th Dec, 2007 at 10:44:10pm
The metro ran a max of 7psi with a similar cr, wouldnt recommend going any higher (without adressing cr & fitting an IC), but you will need to recalculate the cr if the head has been skimmed (would of been skimmed if head was warped/ head gasket problems, reset rocker geometry)
Edited by shane on 5th Dec, 2007. |
5th Dec, 2007 at 10:56:05pm
how would i identify what gearbox i have is it the dam 66 etc numbers |
5th Dec, 2007 at 10:59:44pm
There is a guide to idenifieng engines and gear boxs in a mini mag a few years back?, I will be most supprised if there isnt the info somwhere on this site, have you tried the seach button?
5th Dec, 2007 at 11:20:51pm
yeah no luck yet. is it possible to buy re-build kits for a standard hif44 to convert it to a sealed unit. Edited by spudmini on 5th Dec, 2007. |
6th Dec, 2007 at 02:38:41am
Oddly enough, the Metro Haynes manual that I recently bought on Ebay arrived today. In the back on page 176 it has engine codes. There it states that 12HC01AA is for a 9.75:1 compression engine. According to this manual, which covers 1980-1987 Metros, 1985 and on Metro 1.3L engines had 9.75:1 compression standard, and only the turbo engine had 9.4:1 after 1984. There are a few engine codes listed as 8.0:1.
Edited by fortfun on 6th Dec, 2007. 1275 with Back Door Turbo |
7th Dec, 2007 at 07:32:15pm
you done your homework mate well done. so 9.75:1 is my cr. are the pistons standard. the numbers are at the top of the thread
7th Dec, 2007 at 08:01:21pm
can't find anything on that piston number so far. You should find an AE pistons dealer and get them to look up the dish size on it. If you've removed a piston though, it should be easy to measure with a piece of plexiglass and a pipette. 1275 with Back Door Turbo |
7th Dec, 2007 at 08:37:44pm
I have just dug out my genuine Austin Rover workshop manual for the Metro, and the 12HC01 is indeed listed as 9.75:1. The engine is a 1986 vintage, as well.
On 6th of Dec, 2007 at 02:38am fortfun said:
Oddly enough, the Metro Haynes manual that I recently bought on Ebay arrived today. In the back on page 176 it has engine codes. There it states that 12HC01AA is for a 9.75:1 compression engine. According to this manual, which covers 1980-1987 Metros, 1985 and on Metro 1.3L engines had 9.75:1 compression standard, and only the turbo engine had 9.4:1 after 1984. There are a few engine codes listed as 8.0:1. Dunno if it is right, but it is the only document I've seen so far that has some authority behind it. The online sources I've found are just spreadsheets with no hint of where their data came from. |
7th Dec, 2007 at 09:48:11pm
you people are too good! |
