Home > Help Needed / General Tech Chat > anti run on thing
stevenford_uk
Member #: 144
what is it, whats it look like, is it the thing on the fuel line next to the fuel pressure regulator, is it needed, how do i wire it in?
turbo hogster
Member #: 178
stowmaket suffolk
anti run on valves are a pain in the arse, they tend to leak air and lean out carbs, not a good thing on a turbo.
best way matey is like i do which is to put it into gear lift clutch and when it sarts to bite turn off ignition works a treat.
t3gav
Member #: 229
Gavin@minispares.com
kent
i asked a question about it a couple of days ago so you can look at my posts, its not joined to the regulator its a small box with a plug on it that has a hose which goes to the carb on the passenger side, if you look on photos its the one people block up with a bolt like myself, not worth the hassle! hope this helps. gav
