| Home > Wanted > 1275 Std Hepolite/Powermax pistons | |||||||
6th Dec, 2007 at 12:22:07am
Looking for a set of the hepolite Powermax 1275cc Std size pistons. They need to be the Powermax jobbies with the oil drain holes, rather than the factory fit piston and the slots.
![]() 143 Posts Member #: 1506 Advanced Member Cheshire |
6th Dec, 2007 at 06:16:25am
I have some out of a standard MG Metro 1275 A+ that are just about to come out to make my 1380. Not sure if this is what you want. I can get the part number off them tonight, but I know you are not too far from me, pop over and take a look if you are in a rush. Edited by dn89mini on 6th Dec, 2007. Check out the (slow) progress at.......
6th Dec, 2007 at 01:27:09pm
http://cgi.ebay.co.uk/MINI-MG-METRO-TURBO-...1QQcmdZViewItem
In the 13's at last!.. Just |
6th Dec, 2007 at 01:30:03pm
i'm watching them with interest Edited by minimole23 on 6th Dec, 2007. On 7th Oct, 2010 5haneJ said:
6th Dec, 2007 at 07:59:12pm
The ones in mine are 21962 standard size. The engine is sat waiting for a strip down ready for machining so there is no rush. If you are interested send me an email. Check out the (slow) progress at.......
6th Dec, 2007 at 08:12:10pm
7th Dec, 2007 at 10:43:19am
PM'd you my email in case you want them Check out the (slow) progress at.......
7th Dec, 2007 at 01:05:04pm
On 6th of Dec, 2007 at 07:59pm dn89mini said:
The ones in mine are 21962 standard size. The engine is sat waiting for a strip down ready for machining so there is no rush. If you are interested send me an email. Thanks mate, but I have a brand new set of those pistons to use as a last resort, £32 from Minisport
On 6th of Dec, 2007 at 08:12pm Vegard said:
Sprocket:"Back of the net"! Vegard, not sure what you are trying to say Do you have some of these and this is your way of saying that i have scored? LOL
It needs to be the higher performance Powermax jobbies with oil drain holes. The standard pistons have a slot. These are going in a high reving engine so the standard Rover jobbies, while up to the job for a short period, are not what I am really after. If I cant find the pistons Im after, then I will have to use the New ones I have. I have my eye on those turbo pistons also, but there is too much cc in the piston to start with and im not skimming the block and piston to get the CR down Edited by Sprocket on 7th Dec, 2007. On 26th Oct, 2004 TurboDave16v said:
13th Dec, 2007 at 12:44:06pm
13th Dec, 2007 at 10:30:45pm
Thanks mate, But the 21253s are EXACTLY the same as the Rover piston, Ive had the two side by side On 26th Oct, 2004 TurboDave16v said:
