Home > Help Needed / General Tech Chat > bleed valve/actuator
adam1330
Member #: 238
essex
just want to check that my bleed valve is positioned correctly.
t piece on the turbo, one way is blocked, the other way goes to the actuator and the bleed valve is fitted along this pipe, correct?
the bleed valve has another connector on the bottom which isn't connected to anything, is that o.k?
SumpNut
Member #: 28
Yup its fine, the third connector is for a second bleed valve - this is not nessasary
