Home > Help Needed / General Tech Chat > actuator
adam1330
Member #: 238
essex
i have a unknown actuator fitted, if i removed the bleed valve would i then be able to tell what psi actuator it is?
If you drive the car with the bleed valve fully closed the engine will only boost to what the actuator is set to. So drive it and keep an eye on your boost gauge.
Phil. *smiley*
