| Home > Technical Chat > turning the turbo | |||||||
![]() 514 Posts Member #: 2104 Post Whore Essex - UK |
10th Dec, 2007 at 01:10:59pm
When I got my turbo T2(new) I found the compressor housing pointing directly at the baulk head. I had a look on TM and found nothing so looked around on the net and came across this
"Tuning should be a compromise between what is possible and what is necessary"
10th Dec, 2007 at 03:53:05pm
You've got it all spot on there |
10th Dec, 2007 at 06:45:46pm
As Nic says you're spot on.
11th Dec, 2007 at 12:56:16am
On 10th of Dec, 2007 at 06:45pm Rob H said:
As Nic says you're spot on. Strangely clocking the turbo has been covered in the past, but I can't seem to find any of the old post either. ALEX B ???????????? help !
Edited by BENROSS on 11th Dec, 2007.
