Home > Help Needed / General Tech Chat > piston/bore clearance
mark4765
Member #: 249
does anyone know what the ideal piston to bore clearance would be using omega cast pistons and turbo block at +20 ???
regards mark
Edited by mark4765 on 29th Jun, 2004.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Ring Omega and ask :)
alex
AlexF
Thought this figure came as a spec with the pistons. Its all down to the thermal expansions at a guess. Omega is the place to ask *smiley*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Yeah it should do, but some manufactures assume...
Giving them a ring is the best way, nothing like info from the horses mouth!
Alex
AlexF
mark4765
Member #: 249
cant get through!
mark4765
Member #: 249
got through in the end...they recommend between 2 and 2 1/2 thou
Skinns46
Member #: 165
Cambridge
Apparently for every inch in diameter for the piston you've got to give 1 thou clearance. (2.5 inch piston diameter : 2 1/2 thou clearance).
I could be wrong. And the top of the piston is going to have more clearance than the skirt.
Edited by Skinns46 on 30th Jun, 2004.
http://photobucket.com/albums/y139/Skinns46/
The top must have a greater clearance you mean surely?
evolotion
Member #: 83
Glasgow, Scotland
iv deleted al my old mails, but for my forged pistons the clerances were greater, best to jsut fone and askrather than assume.
Denis O'Brien.
All the Megas I've measured have been 71.06 in .020. I have my blocks bored 71.12 That's 0.06mm clearance.
cheers Vegard
so your pistons was 2.7976inch
and your block was bored to 2.8000inch
giving 0.0024inch clearance 2.4 thou?
isnt 6 years a record for you too ? *tongue*
