| Home > General Chat > engine mounts/ steady bars HELP!! | |||||||
![]() 1128 Posts Member #: 142 Post Whore Winchester |
29th Jun, 2004 at 12:22:57pm
my girlfriend's mini has a problem. Edited by clubman_dan on 29th Jun, 2004. |
![]() 42 Posts Member #: 141 Member |
29th Jun, 2004 at 12:37:41pm
Some minis are fitted with a steady bar that goes from the gearbox to the subframe, but it dont think it was fitted to all of them. What year is it?
29th Jun, 2004 at 12:42:30pm
its a 1987 mini 998.
29th Jun, 2004 at 12:43:23pm
i am also sure that not all minis had these lower steadies, mine didn't until i got a new engine |
29th Jun, 2004 at 01:11:37pm
Our '86 mini has a front steady, there is a bracket that fits to the front right hand side of the gearbox and then a bar to the front of the subframe. I don't think there's ever been one that fits to the flywheel housing. |
29th Jun, 2004 at 01:52:09pm
yeah thats the one i mean
29th Jun, 2004 at 01:52:41pm
so do you think it makes any difference considering some minis have none and don't suffer the same problems? |
29th Jun, 2004 at 02:39:24pm
Does make a bit of difference, but i'd have thought if you had the ultimate steady this would have prevented it from moving too much.
29th Jun, 2004 at 02:39:59pm
I run with a single top engine steady (as in the standard dog bone), no lower ones and with new engine mounts each side and new dog bone rubbers and have no problems whatsoever. Plus im not nice to it either, thats an mg metro running 75bhp. |
29th Jun, 2004 at 06:06:56pm
ill also be trialing just using the dog bone. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
![]() 151 Posts Member #: 165 Advanced Member Cambridge |
29th Jun, 2004 at 09:46:55pm
I'd say get new standard engine mounts (there pritty cheap) and deffo new engine steady bushes. Powerflex ones are good. |
29th Jun, 2004 at 10:29:18pm
i think we'll just have to change the mounts and the steady bar bushes and see what happens then.
29th Jun, 2004 at 10:54:40pm
Dont know if you mentioned, but does that engine actually rock when you push it backwards/forwards? If its same problem as i had anyway the top mounts were pants, and the exhaust had hit the bulkhead at some point, leaving it bent, so when accelerating it hit the floor pan even with new mounts. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
29th Jun, 2004 at 10:57:09pm
yeah thre is some movment when you grab the rocker cover and rock it back and forward, you can see it at the end of the steady bar. do oyu think it might just be the bushes?? |
30th Jun, 2004 at 06:23:00pm
Yes you can try replacing the bushes first. If that fixes it your alright. but in my case because the engine was moving so much the engine mounts got twisted and fell apart. |
