| Home > Help Needed / General Tech Chat > Blocked Carb? | |||||||
16th Dec, 2007 at 04:43:57pm
Went to start the car again after about 3 months of being stood still, it cranks over ok but no fuel is getting to the carb, looking at the little fuel filter I have after the pump and between the carb there is fuel at the bottom but none moving through.
16th Dec, 2007 at 05:49:43pm
Take off the float chamber cover and check the needle valve isnt blocked..
16th Dec, 2007 at 09:15:25pm
needle float valve sticking
16th Dec, 2007 at 09:49:51pm
On 16th of Dec, 2007 at 05:49pm t2clubby said:
Take off the float chamber cover and check the needle valve isnt blocked.. When you take the pipe off the carb and run the pump does it glow properly? as it should piss out with the pump running. Yeah it shoots out when I crank it ive got a mech pump its only on me n/a so the pump is ok! On 16th of Dec, 2007 at 09:15pm BENROSS said:
needle float valve sticking Sounds like it should be something like that thanks guys! So do I just take the carb off, take the float chamber cover off the bottom and pull the bits out cleaning it all up etc? Thanks! Rich |
17th Dec, 2007 at 12:18:17am
yes rich, inspect the needle valve these unscrew out its, made of brass
17th Dec, 2007 at 04:29:06pm
Got it going and it runs well now!
