| Home > Help Needed / General Tech Chat > Main bearings | |||||||
16th Dec, 2007 at 06:32:10pm
Are these the late type with a non groved half?
16th Dec, 2007 at 06:37:03pm
Yup! On 13th Jul, 2012 Ben H said:
16th Dec, 2007 at 06:59:21pm
I believe the lower one is plain.....I'm learning slowly :) On 19th Jan, 2010 wil_h said:
17th Dec, 2007 at 12:14:13am
thats correct milamber
17th Dec, 2007 at 02:00:46am
OK Thanks lads..
17th Dec, 2007 at 11:08:48am
On 17th of Dec, 2007 at 12:14am BENROSS said:
thats correct milamber these btm plain bearings give 80% more load bearing ....... so they say (leyland engineers) But less oil film
17th Dec, 2007 at 01:35:44pm
Can't quite see where the 80% more load bearing capacity comes from.
17th Dec, 2007 at 06:01:46pm
Don't want to sound stupid, but doesn't the old style give better protection at startup due to the groove? On 19th Jan, 2010 wil_h said:
17th Dec, 2007 at 06:28:31pm
On 17th of Dec, 2007 at 06:01pm milamber said:
Don't want to sound stupid, but doesn't the old style give better protection at startup due to the groove? It gives better protection all the time. On 13th Jul, 2012 Ben H said:
17th Dec, 2007 at 06:49:40pm
so the older grooved type gives more wear protection but the later non-grooved give better load protection?
17th Dec, 2007 at 07:20:03pm
I can see your logic there mini_majic
17th Dec, 2007 at 07:25:18pm
The plain ones are NO GOOD in a high revving engine if the crank hasn't got x-drilled mains. On 13th Jul, 2012 Ben H said:
17th Dec, 2007 at 07:35:58pm
got x-drilled mains on mine.
17th Dec, 2007 at 07:37:00pm
On 17th of Dec, 2007 at 07:25pm Vegard said:
The plain ones are NO GOOD in a high revving engine if the crank hasn't got x-drilled mains. going to dissagree with you there old boy,lol. and i can prove it , but it needs me take some piccies, carl Edited by fastcarl on 17th Dec, 2007. |
17th Dec, 2007 at 07:47:06pm
few so my brain does sort of work |
17th Dec, 2007 at 07:49:06pm
Another thing...Don't Federal Mogul own Vandervell or vice versa?????
17th Dec, 2007 at 08:30:24pm
On 17th of Dec, 2007 at 07:49pm milamber said:
Another thing...Don't Federal Mogul own Vandervell or vice versa????? Edit: Ignore that, answered my own question. Its states that on Avonbar website! it used to say OXO on the side of busses but you couldn't buy some off the driver, |
17th Dec, 2007 at 08:40:16pm
17th Dec, 2007 at 10:14:06pm
The plain ones are NO GOOD in a high revving engine if the crank hasn't got x-drilled mains. going to dissagree with you there old boy,lol. and i can prove it , but it needs me take some piccies, carl Yes, but you run 800yards in one complete season.
With no discussion, with non x-drilled mains, the big ends would only be fed with oil 50% of the time they would with "old" main bearings. That cannot be good? Edited by Vegard on 18th Dec, 2007. On 13th Jul, 2012 Ben H said:
18th Dec, 2007 at 01:06:47am
Whats God got to do with it?
im with you on the whole thinking of reliability with this one milamber. i will be using mine everyday so will need reliability.
