| Home > Help Needed / General Tech Chat > TPS or MAP? | |||||||
45 Posts Member #: 2014 Member Carlisle |
18th Dec, 2007 at 06:51:28pm
I;m about to buy megajolt for my turbo project, anyone who currently uses this setup, which is the best to buy, the tps version or the map version? |
18th Dec, 2007 at 06:54:35pm
for turbo the MAP is better. ive just been reading this up on one of the MJ write ups. |
18th Dec, 2007 at 06:59:35pm
Yep indeedy. You want the MAP version. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
18th Dec, 2007 at 08:57:13pm
kool thanks guys, the only difference i notice is that is has a vaccum pressure sensor for the manifold. which i guess will be very usefull for running a turbo application. |
18th Dec, 2007 at 09:01:20pm
yeh, so it will give you/allow you to make adjustments under boost rather than at set throttle point. as (as you no doubt know) boost is also dependent on load.
18th Dec, 2007 at 11:53:53pm
i have tps and map Crystal Sound Audio said:
19th Dec, 2007 at 05:30:58pm
On 18th of Dec, 2007 at 11:53pm wolfie said:
i have tps and map show off
19th Dec, 2007 at 11:09:56pm
me too |
19th Dec, 2007 at 11:38:25pm
as said...
AlexF |
19th Sep, 2008 at 12:23:01pm
So, reading this. For an n/a application would tps be the best bet and then convert it to map when I go turbo.
19th Sep, 2008 at 12:35:34pm
Nope, MAP is best in all cases. Sometimes it is difficult to get a good map signal on NA, but it can usualy be done. http://www.twin-turbo.co.uk
