Home > For Sale > Valve spring spacers
I've just had to buy 200 washers to use as valve spring spacers.
They are 12mm BS4320 Class C washers, 2.5mm thick which happen to be the perfect fit.
You need these if you are using large bore valves in a small bore head.
I only need 16 or 24 so have some spare.
They cost me less than 3p each, so they are free to TM members as long as you cover the postage cost.
