| Home > Help Needed / General Tech Chat > mini injection tank and pump | |||||||
117 Posts Member #: 144 Advanced Member |
30th Jun, 2004 at 01:22:33pm
i have just bought a tank and pump off a late injection mini. |
126 Posts Member #: 244 Advanced Member |
30th Jun, 2004 at 02:06:08pm
see the "how to" section on this web site, there is some excellent safety considerations as well as a link to a diagram.
Speedster turbo under construction |
30th Jun, 2004 at 10:11:36pm
i got advice off billydude, the copper tab is the +ve and the steel one is the -ve :) Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
30th Jun, 2004 at 10:12:24pm
btw, i dont understand the faq no matter how many times i read it, and i did A lelel electronics so mines just on with the ignition via a 15amp fuse until i see one wired with the oil light in real life. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
30th Jun, 2004 at 11:08:53pm
Feeb's i did gcse electonics and you shouldnt even need a diagram!!
30th Jun, 2004 at 11:14:02pm
i was just going to wire it straight to the ignition via a 15A fuse, would this be ok, or dangerous? i can understand the how to either |
1st Jul, 2004 at 12:54:17am
its dangerous cos if you have a crash then when the engine stalls your pump will carry on going and you run the risk of spraying fuel everywhere.
1st Jul, 2004 at 02:53:01pm
stevenford managed to get his to fit perfect with same mounts in a J reg shell, why should i be getting problems in my B reg shell????? Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
1st Jul, 2004 at 07:01:29pm
do not run your pumps even temporay on just the ignition. you never ever know when an accident will happen. get to the scrapyard and get an inertia switch, found very easy on most later peugeots ,citroens, rovers ,early fords with efi etc cost about 2 quid easy to wire up to.
1st Jul, 2004 at 11:19:57pm
what do you mean an inertia switch????
2nd Jul, 2004 at 09:16:24am
An inertia swith is a little box that is bolted to a rigid point in your car (mine is on the predal box).
![]() 1128 Posts Member #: 142 Post Whore Winchester |
2nd Jul, 2004 at 01:59:01pm
how much shock would be required to trip the switch?
2nd Jul, 2004 at 02:24:28pm
its an impact of sharp bump that sets them off, not really an emergency stop.
