Home > Help Needed / General Tech Chat > 1098 or 998 Center Main Cap
smallcarsneedlovintoo
Member #: 2159
SC, USA
Does anyone know where I can find a 2 bolt steel center main cap for a 1098 or 998? I have found plenty of places that sell a steel strap, but I would rather replace the whole cap if possible. I have also found places that sell a 4 bolt cap… I would rather just 2 bolts.
You wont get a 2 bolt, or atleast Ive never heard of one. Why not fit a 4 bolt? Its no problem to drill and tap 2 more holes.
Paul
do you realise you will incure the cost of a line bore when fitting a steel cap.
carl
carl
But you'll incur that cost fitting any new/different cap, as they were all linebored so caps aren't interchangeable.
Edited by wil_h on 31st Dec, 2007.
Member #: 2159
SC, USA
So would you guys recommend the 4 bolt or the strap mod? My concern is that this is a 1098, that seemed to have problems without the boost, I want to make sure the center main does not fail.
im sure if you suitable limit the revs it will hold up fine?
It depends on how much money you want to spend. A strap will not need line boring so is cheaper.
For example I rev my 1380 over 9,000rpm regularly over the last 8 years or so with a strap.
Paul
