Home > General Chat > Steel and brass
Anyone know whats heavier?
Paul
Brass - 0.306 lb/cu in
Steel - 0.283 lb/cu in
So Brass is heavier.
Sorry abou the units, but it came from my old Newnes Engineers Pocket Book.
google it lad,
brass is 8.5 gms per cm3,
ans stainless steel is 8 gms per cm3, so even taking into account the dromium in stainless steel brass will still be slightly heavier than your average carbon stll,and most ,if not all steels,
carl
Google? its easier to ask you.
Cheers lads
Paul
Leadfoot
Member #: 781
who is the stronger metal?
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Depends on what you want to use it for.
On 19th Jan, 2010 wil_h said:
Nothing major. I compared an alloy door hinge to a steel one the other day to see what weight saving I would get, The hinges on my car are brass so didnt know how that compared. It would seem now though that I will get an even bigger saving as the brass ones are even heavier.
Paul
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Can't say I've ever heard of brass hinges fitted to cars.
Edited by Jason G on 1st Jan, 2008.
Early MK1 were brass. Theyre quite rare.
Paul
Carl
Member #: 95
liverpool-on-sea
a kg of brass weighs the same as a kg of steel.
LOL
Jason G
Member #: 1459
En-suite user
Braintree, Essex
lmao
But a ton of feathers is lighter than a ton of lead. lol
Paul
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
Trust carl *tongue*,
A ton of feathers and a ton of lead weigh differant on the moon though dont they?
Edited by Jordan on 1st Jan, 2008.
yes, about a sixth of what they would on earth.
Jordan
Member #: 1392
Yes but would the ton of feathers weigh differant to the ton of lead?
no,
your thinking of the rate they fall at.
the ton of feathers falls slower on earth due to air resistance.
if you have two of the same weights of course it will weigh the same =/
are you sure.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I sense Carl has a hidden argument here. My intelligence is often hidden by beer most of the time, so I'm going to sit on the fence on this one till I'm sober enough to come out with some amazing piece of fact.
