| Home > Help Needed / General Tech Chat > engine wear rates | |||||||
1st Jan, 2008 at 06:09:48pm
OK,
2nd Jan, 2008 at 12:19:51pm
Judging by the lack of response, i think the answer is that we do not really know which wears fastest.
2nd Jan, 2008 at 02:58:24pm
On 2nd of Jan, 2008 at 12:19pm Paul S said:
I think that it is possibly because parts break rather than reach the "worn-out" stage. Thanks paul, That is the way I was thinking so I was looking for the "budget" option for my first attempt (I've just ordered $550 of MS II kit, Stimulator and LC-1 wideband and apart from VAT, I don't know for sure how much more Customs will add) so I want to keep engine cost low (without being stupid) and using what I have that is servicable. For example, I have one crank that is on a -010/010 grind but measures at -0100X0012 (mains) and -0100X0105 (big ends) ie, minimal wear and max 1/2 thou ovality and another on std/std but measures -0002X0005 (mains) and -0005X0015 so noticable wear and 1 thou ovality. If I was rebuilding a standard engine I'd take the badly worn one and regrind it, but, in this case I'm tempted to just use the slightly worn one (neither are the later forging with the rolled radius anyway). Pistons vs chambers to get the CR down is worth a thought but I think most of my spare heads have already been skimmed once. Also, I think a decent set of pistons is probably the next best investment after diff/gearbox upgrades, it's just a question of whether I buy a set to fit current bores, or rebore and buy larger - your suggestion of just a hone might be best... And, no, not silly boost figures, probably 0.5 - 0.7 bar (7-10 psi ?) Rod. Schrödinger's cat - so which one am I ??? |
2nd Jan, 2008 at 06:07:39pm
paul has sumed it up for you
