| Home > Help Needed / General Tech Chat > compression ring thickness | |||||||
2nd Jan, 2008 at 08:40:40am
what should the thickness of the compression ring for 20831 pistons be. I have measured mine to be 1.59mm or about 0.61 - 0.62 in imperial.
2nd Jan, 2008 at 09:34:09am
What matters is the gap between the ring and the slot in the piston. Measure this. Brand new rings may still be unuseable if the piston is worn. On 13th Jul, 2012 Ben H said:
