Home > Help Needed / General Tech Chat > clutch / flywheel
bertieboo
Member #: 1613
N. Ireland
I am sure this topic has been asked before but i couldnt find it.
Im converting to a pre verto type clutch set up and looking to buy a lightened flywheel - my question is can i run a pre ingaged lightened flywheel with the pre verto clutch or do i need to get an inertia flywheel?
cheers,
You can run the pre-engaged flywheel as long as you have the pre-engaged starter.
bertieboo
Member #: 1613
N. Ireland
ok thats great thanks.
just use whatever starter type that matches the ring gear on the flywheel
