Home > General Chat > bolt size of bottom pully
alandavies215
Member #: 1844
BURNTWOOD, staffordshire
just a quick one i am going to get a trigger wheel fro trigger wheels .com but i dont know the size the middle hole should be does anyone know of the top of there head, thanks
do you mean the od of the damper?
this has definately been covered before, but i cant find the thread, but iirc its around 150mm (dont hold me to this!!)
alandavies215
Member #: 1844
no i meen the diameter of the internal hole that the bolt goes through that holds the trigger wheel on
ah, not sure, bear in mind this bolt is recessed in the damper, so it wont be a simple sandwich affair
The hole through the centre is spot on an inch dia.
