| Home > Help Needed / General Tech Chat > Red top (dry cell) battery | |||||||
2nd Jan, 2008 at 09:31:23pm
Ive done a search but not got anything specific.
2nd Jan, 2008 at 09:34:41pm
I use a redtop 15, I find it fine for my use. On 15th May, 2009 TurboDave said:
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
2nd Jan, 2008 at 09:40:10pm
really, you're only using a 15 jim? We use 15s on the historic f1s at work. It will only just start them without a jump battery! I would say a 30 would be more suitable if you plan on using it on the road occasionally. |
1300 Posts Member #: 829 Post Whore essex |
2nd Jan, 2008 at 09:41:13pm
I' ve used them to over the years
1293 Turbo mini
2nd Jan, 2008 at 09:47:28pm
you must use an alternater or you will soon run out of volts,[or amps]
2nd Jan, 2008 at 09:51:49pm
yes and you must NOT boost charge these battery it will damge them 1293 Turbo mini
2nd Jan, 2008 at 09:58:47pm
Hi, i will be using the alternater that matty was selling ,45amp i think.
2nd Jan, 2008 at 10:03:16pm
charging by alternator is fine 1293 Turbo mini
2nd Jan, 2008 at 10:04:21pm
I use an alternator, I can run fuel pump, water pump, injectors, boost soloniods, and lights, and ecu without problems. While running at pod, I must have started my engine over 20 times in the day, never had battery problems, but I do have an alternator. On 15th May, 2009 TurboDave said:
2nd Jan, 2008 at 10:06:14pm
Ive used a 15 for about 4 years. No problems at all, its never gone flat even when I leave it connected all winter with no use. I use it on the road and strip.
I seriously doubt it! |
2nd Jan, 2008 at 10:06:56pm
Wel id like to think your not daft jim so 15 sounds good to me then.
