| Home > Help Needed / General Tech Chat > ooorrr nooor, clutch flucked! | |||||||
162 Posts Member #: 228 Advanced Member |
2nd Jul, 2004 at 10:51:30pm
any ideas on this one guys before i strip it down sunday, been out in my mini tonight, fine all the way there, left it for about an hour, came back, started up, pressed clutch to get a gear and the pedal went straight to the floor, as if it had a hydraulic leak, got reverse, just, tried to get a forward gear, nothing doing, let the clutch back up, tried to press again and this time its absolutely rock solid which is how it still is now, |
4th Jul, 2004 at 08:19:36pm
sounds hydraulic related to be honest. Is the hose a std rubber one? close to the exhaust or anything that could make it hot and maybe break down inside to block up? |
126 Posts Member #: 244 Advanced Member |
4th Jul, 2004 at 11:27:10pm
does the arm on the clutch housing move? I have had a similar problem but with my brakes before, pedal was rock hard but no brakes, turned out to be seized pistons on half the system and one of the pistons had managed to get itself wedged in the bore where a line of crap had accumulated. It is a bit worrying that the engine tries to die when the clutch is pressed though. Sounds to me that the release bearing has given up the ghost so the clutch slave is at maximum travel (hence rock hard) or something along those lines, sounds like it may be time to get a new clutch kit fitted.
Speedster turbo under construction |
5th Jul, 2004 at 08:41:06am
Read that he found the flywheel bolt had come loose! ooo er?!
5th Jul, 2004 at 08:18:04pm
would explain the rock hard pedal! VERY lucky! Speedster turbo under construction |
8th Jul, 2004 at 02:11:44pm
yep!
8th Jul, 2004 at 05:47:26pm
woohoo! all fixed now, and the clutch pedal is so different, flywhell must have been on cock eyed before (whoops!)
just going back together today, should be good for avon park
