Home > Help Needed / General Tech Chat > lap top screens
Carl
Member #: 95
liverpool-on-sea
my laptop screen keeps getting green bits on it where the black should be like under the shadows of cars etc,. does this mean its on its way out?
thanks
do a screen grab and post it so we can have a look.
evolotion
Member #: 83
Glasgow, Scotland
it mroe than likely meens your graphics card drivers are wrong, or your display settings are wrong :)
Denis O'Brien.
Carl
Member #: 95
liverpool-on-sea
only doesit now and again so il try and gab it next time
thanks
Nicky
Member #: 333
Tadley, Hampshire
It's more likely to be the screen itself, screen grab wont work because our screens probably work properly!
Ben H
Member #: 184
Melton Mowbray, Pie Country
Yep I doubt a screen grab would show anything. It is most likelt to be a lose connection between the motherboard and the screen. On older laptops that have been opened and closed a lot the flexi cable between the screen and main box can ware. Open it up and push all the connections on.
http://www.twin-turbo.co.uk
Carl
Member #: 95
liverpool-on-sea
i think your right ben, it just did it whilst i were looking at the frog build in the shadded areas and behind the grill were flickering green so a wiggled me screen and it came and went so thiking same as you ben.
thanks for all help
Do a screen grab.
Then we can establish if it's a physical problem or a hardware/software fault..
