Home > For Sale > Various bits and bobs
2 x MPi Idle Air Valve, brand new in bag (one bag has been opened, but its still new and never been used) £12.50 each posted.
Left hand stat in picture now sold. Two on the right remaining, external bypass thermostats. one 80c and the other 83c. Good for your K head conversion, especialy if you are running an electric pump. I'll get a picture up shortly. £5.50 each posted.
Cooper S water pump cast pulley. £20 posted
Maniflow LCB missing the 'Y' piece, really good condition, just missing the Y peice. £15 collected, but could post out but recon on £5 costs
Maniflow LCB to cat converter link pipe with knuckle joint only 2k miles and painted in HT grey paint. £7 posted, or, will thow it in with the LCB for free
SOLD MG metro reconditioned head, 35.7mm inlet valves, leaded. Work was done by Racespec many many moons ago (for those who dont know, Racespec was originaly Howley Racing) and has been on the shelf since, some surface rust on the manifold face, some surface rust in the ports and in the chambers, but nothing that wont clean up. This has no bypass. I recon it has been skimmed to bing the CR up, but dont know what the chamber CC is, other than that it is a standard spec head but recut valves. No idea on price, Open to offers. Just need some room.
Set of four MJY10029 injectors. Same type as the Mini MPi MJY100460, BUT 230cc. £15.50 posted
EDIS4 module with connector and tails, Ford DIS coil £25 posted
EDIS4 module, no connector £5 posted
Mini Mpi DIS coil and plug leads. £25 posted
Edited by Sprocket on 5th Jan, 2008.
Oh and I also have a stainless DTM center exit with a bash in the bottom. Nothing that would reduce performance (lol if you call these performance). No hanger bracket, just the back box. to fit 2" system. This is one of those sold by Hudersfield shiney spares by the looks of it and retail for £80+. Im only looking for £15 collected, could post out but recon on £5 costs. Really need to get a picture up for this as the bash isnt rally an issue. as long as you dont look underneath you would never know. Must be good for some one on a budget
Head sold
Ok The 78 stat is infact 79c, whoopsie, sorry
In the picture below, the 79 is on the left, the 80 is in the middle and the 83 is on the right. The inlet is on the side and the bypass outlet is at the top on all.
Here is the DTM, this pic is the good side, lol, unfortunately that side is the top *laughing*
Here is the bash in the bottom
and here it is from a different angle
79c stat, the one on the left is now sold
Colin, please can I buy the other two stats?
You may indeed
Bugger...Where did the stats come from?
