Home > Help Needed / General Tech Chat > wont rev up
ive changed the engine in my daily driver and it starts and idles great but wont rev up ?? it revs but very slowly the engine and encilleries were lifted out of the donor and straight into mine
speedster turbo
Member #: 244
does it idle smoothly? When it revs slowly, is it revving smoothly or does it sound like it is misfiring? Check the dashpot oil (I presume it is an A or A+ you are talking about) There are so many variables causing this it is hard to list.
Check everything from earth straps to fuel pump, I presume it ran perfect in the donor?
Speedster turbo under construction
i topped dashpot and did an oil and filter change after in was in but before it was fired up
there is no missfire whatsoever it seems smooth but is also over running
any ideas ??
speedster turbo
Member #: 244
over running or "dieseling" is usually caused by carbon build up around the valves which glows when the engine is running, when you kill the ignition, the compression assists the carbon to keep glowing and it ignites the fuel/air mix. Have you tried disconnecting/replacing that pipe on your carb? it may be that the vent pipe for the float chamber is blocked and starving the engine of petrol. at could also be your vacuum advance being knackered on your distributor, take the pipe off the inlet manifold that goes to the dizzy, take the dizzy cap off and suck down the pipe, depending on which dizzy it is, you should see the internaly moving, if they don't or you can freely suck and draw air, the diaphragm is split.
