| Home > Help Needed / General Tech Chat > 1098 Engine Build - Is it a good idea? | |||||||
8 Posts Member #: 2159 Junior Member SC, USA |
9th Jan, 2008 at 01:05:09am
I am in need of motivation! |
9th Jan, 2008 at 01:51:45am
longer strokes make more torque and torque makes power, a turbo is a torque multiplier ..... this togeather with longer strokes ar fab!
9th Jan, 2008 at 04:11:14am
Go for it, make sure the rotating assembly is balanced, and strictly keep the revs down, and it will be very torquey. In my younger days I built a 1098 based NA engine with a 12G295 head and a Piper 270 cam, it was as quick as a 1275, and pulled really well.
![]() 189 Posts Member #: 1774 Advanced Member Sydney AUS |
9th Jan, 2008 at 09:29:25am
Ben and I both have 1100 Turbo's
1132cc Turbo ~120 bananas ATW - Fun Fun Fun
9th Jan, 2008 at 05:48:09pm
Its tosh
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
13th Jan, 2008 at 07:08:49pm
I too am building a 1098.
Metric is for people who can't do fractions. |
13th Jan, 2008 at 07:09:06pm
How did I double post ??
Edited by Alex on 13th Jan, 2008. Metric is for people who can't do fractions. |
14th Jan, 2008 at 02:40:55am
It was a guy at Vmax as well that swore up and down that the 1098 was a bad idea and that the crank was good for 65 hp max! Either way, I appreciate all yours posts and I have definitely decided to continue on with the 1098....
![]() 171 Posts Member #: 621 Advanced Member nsw austalia |
14th Jan, 2008 at 06:46:32am
On 14th Jan, 2008 smallcarsneedlovintoo said:
It was a guy at Vmax as well that swore up and down that the 1098 was a bad idea and that the crank was good for 65 hp max! yeh? hmm so how come ive done near 10,000km with a 139hp 1100, hha anyway i use a 12g295 head very similar to the 206 i think/? i use 1275 valves turned down, not sure on the sizes. cam, RE13T works wonders and cheap enough, use your own cam and only $120ish AU for the grind:) 1152cc turboed mini clubman, most powerful 1.1L a-series?
152 Posts Member #: 2190 Advanced Member South Carolina, USA |
15th Jan, 2008 at 02:20:22am
Do they sell the RE13T online somewhere? |
15th Jan, 2008 at 07:29:14am
The 206 and 295 heaqds are indentical bar the inlet locating rings. I'd get some Minispares 26,5 exh valves to clean up the seat and get a proper valve seat radius for sure. The exh. valves will get very hot, and the standard A valves are soft as butter.
15th Jan, 2008 at 07:55:49am
On 15th Jan, 2008 Vegard said:
The 202 and 295 heaqds are indentical bar the inlet locating rings. I'd get some Minispares 26,5 exh valves to clean up the seat and get a proper valve seat radius for sure. The exh. valves will get very hot, and the standard A valves are soft as butter. you mean 206 and 295, 202 is very different. i used new exhaust vales which are harder ? or s/s? not sure anyway turned down 1275 ones so are thick too. not sure if theres anywhere on the new that stocks the re13T but graham russel grinds them here in aus. he would happily post im sure. i think there is someone who sells them but not sure. 1152cc turboed mini clubman, most powerful 1.1L a-series?
and I am just over 130
