Home > Technical Chat > +40 rings
going to order some new rings for the rebuild, i would like to order them from totalseal but actually have no idea of what sizes to order
its not only the diamiter but the thickness
What pistons? Megas?
Edited by Sprocket on 10th Jan, 2008.
yes
turbo hogster
Member #: 178
stowmaket suffolk
be carefull wolfie as i have had probs with the ring packs from minispares as you have read. they were all to small so the gap was to big.
the powermax ones were spot on but didnt fit the pistons, but i would go for the total seal ones and see what they are like
at the mo i are going to trim down some plus 60's
Mirage
Member #: 119
I've experienced the same problem with these rings. The odd one in a pack i had was first compression ring and was a +20 stamped as +40.
I believe that there is most likely a few sets of mega +40 turbo pistons in circulation with the wrong size ring land groove. The set i first had the correct rings fitted but the ring lands had been machined much bigger. I think there was something like 18-20 thou play. Minispares couldn't understand what i was telling them, so i had to call the north to talk to them. The whole batch turned out to be wrong in the end. I think the ring lands had been machined for the standard turbo rings i think, its 5 years ago so not 100%
turbo hogster
Member #: 178
stowmaket suffolk
yes they have now standerdised the ring sets buy all accounts now but for some reason the rings are still to small giving larger than acceptable ring gaps, cant understand this as that way it gives no service live for the rings, 20 thou for compression and 40-50 thou for oil control is way to big.
Mirage
Member #: 119
Minispares may try and standardise there rings. However if pistons go through that are machined wrong to fit the rings, they aint ever going to fit.
Some of the rings i've seen had the wrong size stamped on them !!!
I think the mistakes have happened at Mogul who make the stuff. When i had problems it took me months just to get minispares to check these rings. After much chasing my set was sent with other rings to an engine builder they are friendly with. He confirmed what i had been saying for ages, the rings are stamped with the wrong size.
Easy way forward is,
Don't just put your new rings / pistons in. Check the fit of just the rings in your bores. Check every ring (i had 1 odd one). Check them in the ring lands to.
If they aint in spec send them back.
anyone know what sizes i need to order?
may i ask why you want to fit total seal,
carl
just to give them a try
i ask because i friend of mine ft them to his big pinto grass car and it really did struggle to turn over on starting due to less leak by, had to get a geared starter ,
would you like me to measure the relative thinckneses of a set of rings for the mega range,
yes please
turbo hogster
Member #: 178
stowmaket suffolk
bets way wolfie ie to take block to minispares and fit some which will fit the bores and pistons.
all i know is the power max range doesnt fit apart from the oil control rings
