Page: |
Home > MS Trials & Testing > Megasquirt Port Injection Trial | |||||||
21st Jan, 2008 at 09:29:43am
Very interesting,
21st Jan, 2008 at 09:55:14am
I think that it is just a quirk of the AFR map that came with the default MS2/extra code. It leans out considerably at lower revs.
Edited by Paul S on 21st Jan, 2008. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
21st Jan, 2008 at 11:02:51am
What's your AFR map vertical axis?
21st Jan, 2008 at 11:31:22am
I've just changed the log file as I had got the legend wrong. It definatley is the Inner cylinders that run rich.
21st Jan, 2008 at 12:42:56pm
Ooops,
On 21st Jan, 2008 Paul S said:
I've just changed the log file as I had got the legend wrong. It definatley is the Inner cylinders that run rich. In which case that 10 second bit is even more strange as it's a fair bit off the map just there, and that's the line that should be following the map. Looking closely there are two similar (but much smaller) deviations between outer and inner at 330 and 412. All three are after a short period of high vacuum, but why only the outer cylinders? I'm probably looking in far too much detail, how to bring inners and outers closer together is the important question. Schrödinger's cat - so which one am I ??? |
21st Jan, 2008 at 01:09:27pm
There is a lot more fine tuning that can be done to eliminate some of these quirks. For example, the AFR control is only using the "simple" algorithm. It amy be quicker to react if we use the PID instead.
Site Admin 15300 Posts Member #: 337 Fearless Tom Fenton, Avon Park 2007 & 2008 class D winner & TM legend. |
21st Jan, 2008 at 06:04:37pm
Watching with interest Paul.
62 Posts Member #: 1515 Advanced Member |
21st Jan, 2008 at 09:46:12pm
Well done. Great start |
6743 Posts Member #: 828 Post Whore uranus |
22nd Jan, 2008 at 10:12:43am
paul do you have the option to change the point in crank degrees where the inj open at all ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
22nd Jan, 2008 at 10:20:42am
On 22nd Jan, 2008 robert said:
paul do you have the option to change the point in crank degrees where the inj open at all ? Not in the standard MS2/extra code. The siamesed code has been specifically developed to allow you to input an advance curve. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
22nd Jan, 2008 at 10:25:52am
it would be great if you could just adjust the opening position at different rpm and idealize it at all points to run smoothest ,,then program in to use those points . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
22nd Jan, 2008 at 10:30:17am
Well, we are going to sort out a few reamianing issues with the idle etc then tweak the injection setup on the standard code.
857 Posts Member #: 1778 Post Whore Northants |
22nd Jan, 2008 at 10:37:23am
No mention of me helping at all :(
22nd Jan, 2008 at 10:45:56am
On 22nd Jan, 2008 sturgeo said:
No mention of me helping at all :( If this proves to be successful with the siamesed code hopefully i'll be building up a 1275/1293 running the same design inlet manifolds with a GT1752. I think that the current size inlet plenum would be perfectly adequate for a larger bore 10psi turbo, what do you think dad? OK, When I say "we" I mean "Sturgeo & I". Yes, it's probably just the right size for that. What do you fancy for tea? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
22nd Jan, 2008 at 10:48:25am
No mention of me helping at all :( If this proves to be successful with the siamesed code hopefully i'll be building up a 1275/1293 running the same design inlet manifolds with a GT1752. I think that the current size inlet plenum would be perfectly adequate for a larger bore 10psi turbo, what do you think dad? WELL DONE STURGMIESTER !!!! hows that ? and yes that plenum would be big enough the size is not really affected by boost but by rpm ,higher the rpm the bigger the plenum (up to a point),looking at that ,it would be ok to 14 k rpm so i wouldnt worry ! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
22nd Jan, 2008 at 11:16:12am
On 22nd Jan, 2008 Paul S said:
What do you fancy for tea? Hmm quite fancy curry. how long before we put the 998 in? ready for avon? |
22nd Jan, 2008 at 11:19:25am
Actually, your mum has made some soup. I'll do a curry tomorrow.
22nd Jan, 2008 at 12:53:51pm
Looking good, been reading the updates with great interest, keep us up dated as to your progress.
I'll do a curry tomorrow. Are we all invited? or did you just post that to tease us? Isambard Kingdom Brunel said:
Forum Mod 10979 Posts Member #: 17 ***16*** SouthPark, Colorado |
22nd Jan, 2008 at 02:06:38pm
mmmm, curry tonight :) On 17th Nov, 2014 Tom Fenton said:
26th Jan, 2008 at 03:16:19pm
Tried a couple of different setups today.
Edited by Paul S on 26th Jan, 2008. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
152 Posts Member #: 1074 Advanced Member Northamptonshire |
26th Jan, 2008 at 04:51:24pm
What flow rate injectors are you using and how many?
26th Jan, 2008 at 04:54:39pm
I'm using four of the Rover MPi injectors MY100460. Two per port.
26th Jan, 2008 at 05:10:46pm
It sounds like the engine idles OK with all injectors firing once per revolution. Is that right?
26th Jan, 2008 at 05:29:19pm
It idles OKish, but it's about 16:1 on the outer cylinders and 10:1 on the inners.
26th Jan, 2008 at 07:20:29pm
THATS A POSITIVE ReSULT THAT YOU GOT IT TO RUN NEAR EVEN MIX OUTERS TO INNERS ,oops caps ,supports the idea that with correct injector timing it will all work ,i wonder what the effect of a scatter cam would be on it as it is . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
Page: |
