| Home > Help Needed / General Tech Chat > Pot Joints or Hardy spicers | |||||||
13th Jan, 2008 at 10:27:08pm
Now if the new qauife came in a HS version then it wouldn't matter but it doesnt, it comes with pot joint output shafts. i have a set of HS on the car and they are known to take a bit more abuse due to the output shafts on the diff being slightly larger OD.
13th Jan, 2008 at 10:44:02pm
Go for potjoints
13th Jan, 2008 at 10:48:18pm
Not seen many broken pots TBH...
AlexF |
13th Jan, 2008 at 10:52:47pm
may as well just buy a couple of new pot joints then, only £31 each from minits. then just use the std shafts. not that arsed about spending £60+ each on some comp shafts.
13th Jan, 2008 at 10:54:15pm
I've only seen the one wil/ben broke.
Edited by iain on 13th Jan, 2008. |
13th Jan, 2008 at 11:00:35pm
Im just on std stuff
13th Jan, 2008 at 11:03:02pm
My cars a lot heavier than yours |
14th Jan, 2008 at 08:13:25am
The reason ours broke (most likely) is that Wil put the car on two wheels and kept his foot in. As the wheel in the air came back to the track (it was spinning because it was before we had the LSD) it slowed down very quickly and hence the pot joint went. This had obviously happened several times in its life before it broke.
http://www.twin-turbo.co.uk
14th Jan, 2008 at 09:24:39am
Not sure but it probably wouldn't have helped that your on slicks too. On 7th Nov, 2008 Nic said:
14th Jan, 2008 at 12:10:45pm
The 4x4 kill diffs like that Ben... its not the cars fault lol AlexF |
