Home > For Sale > K1100 rs twin cam cylinder head
Turbo Tim
Member #: 177
Avon Park 2006 Class D Winner
Woburn Sands
as it says, 1 K1100 rs cylinder head with cams and valves, no rocker cover or carbs tho
£250
ono
Tim
16V project underway
bargain!
Turbo Tim
Member #: 177
Woburn Sands
*wink*
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I would love this but alas I need to research a bit first and then theres postage to NI etc etc. But yeah it's a deal alright.
On 7th Nov, 2008 Nic said:
naeJ
m
thought postage to NI was the same as mainland UK for parcels?
no excuse *tongue*
Jay#2
Member #: 648
It is for Royal mail but couriers charge anything they want. RS has lairyer cams than LT doesn't it? Hmmm...
naeJ
m
Jay#2
Member #: 648
Pm'ed (yeah thanks Ian!) *wink*
naeJ
m
The Common K1100 RS and LT cams are exactly the same, no difference. 256 duration and 7.95mm lift
so what has the lairy cams then?
The 8v K100 has the 284 duration cams.
K100 RS 4Valve and the K1
ah right,
so all K100's and no K1100's.
so what difference is there between the k1100 lt and k1100 rs? I thought the RS did have different cams?
tim i am interested but needs to be a little cheaper as
1) i am a tight arsed cnut
2) Fair way for me to come and collect
K1200 RS has the desirable cams for sure. I purchased a K100RS 4v and that had the 7.95mm lift cams in, so it's not gospel.
Only way to tell is by measuring the base to peak and subtracting it from the base circle. If it is circa 8mm it's boggo, if it's over this, then it's the racey cams...
Info on K1200 shows them to be softer than 256, except the RS which is 284.
You could be right Dave. Dont forget that exports to certain countries required cats to be fitted, and the BMW parts lists show lesser 264 cams with 7.95mm lift on these models. So, just measuring the lift isnt the be all and end all*laughing*
If its a known UK model, the K1100LT/RS will be 256 7.95mm lift and the K100RS/K1 will be 284 8.55mm lift. I have seen a few sets of cams that do not contradict this. Motorworks obviously know this also.
Bottom line, if the cam lobes measure 38.855mm in total, they are Pukka*wink* everything else is not quite a guessing game, but close*laughing*
Edited by Sprocket on 14th Jan, 2008.
Turbo Tim
Member #: 177
Woburn Sands
SOLD!!!!!!
