Home > Help Needed / General Tech Chat > Kpa Readings
colas
Member #: 102
Pennsylvania USA
Does any one know how to calculate PSI from the Kpa range in the Megajolt software. I understand 100Kpa is 0psi. But whats the formula for upto say 14psi.
Thanks
Kean
Member #: 341
aka T2clubby
South Staffs
From psi to kpa you multiply by 6.894757
So swap it round for the other way...
100 kPa equals 1 Bar equals 14.5psi
However you seem to be confusing absolute and gauge pressures.
The megajolt uses absolute pressure, with zero being a full vacuum and 100kPa is roughly atmospheric pressure.
Boost is measured as a gauge pressure so 0psig is atmospheric pressure.
colas
Member #: 102
Pennsylvania USA
Yeah so how do you work out what psi is on the kpa area in the MJ software. Like what is 160kpa in boost terms for the engine. Im just trying to work out what the values on engine load are in psi.
evolotion
Member #: 83
Glasgow, Scotland
right 100kpa in megatune is 0 bar boost. 200kpa in megatiune is 1 bar boost
300kpa in megatune is 2 bar boost.
so in that example you can very quickly tell you have 0.6 bar of boost. (from the 160kpa, as its 60 kpa above atmospheric pressure)
1 bar is 14.5 psi so you have 0.6*14.5=8.7psi
its best tho think of boos t in bar if your megasquirted, that way you can tell at a glance what the boost is if your reading in kpa. and vice versa.
do yourself a favour and google "gauge" "gage" and "absolute"
megasquirt measurements are absolute
boost gauge measurements are gauge.
itll help alot if you understand teh difference :)
Edited by evolotion on 15th Jan, 2008.
Denis O'Brien.
colas
Member #: 102
Pennsylvania USA
Thanks evolution that helps alot
