Home > Help Needed / General Tech Chat > SC 3 syncro kits?
Did a search but nuthin came up.
Whats the difference between the 3 syncro kits and 4 syncro kits.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
the 3 sync one does not have a syncronised 1st gear. Parts are generally different
So you just use your original 1st gear??
Whats the difference between this and the clubman set, bar the ratios??
miniminor63
Member #: 672
Oslo, Norway
the 3 sync boxes where only used up till late 60ies. You do not have a syncro ring at first gear at all. They only ever was fitted to remote boxes.
no mike it is a non syncro first, or a crash box, crunch crunchy into first untill you get the knack,
not really ideal ,unless its the ratios you are after.
The ratios on the Clubman and ST kit are very similar to the 3sync ST-kit.
Its the price thats actractive! Ill give it a miss then!
Not worth it. Get a ST or Clubman kit.
ST??
miniminor63
Member #: 672
Oslo, Norway
ST is the kit that minispares sells that also contains the 1st gear and reverse. It has one more bearing in the laygear too.
3 SYNC WONT FIT IN A 4 SYNC CASE
Thats cleared that up lol!
opps didnt realise caps was on.
Just thought you were making a statement there lad!
Edited by MikeRace on 15th Jan, 2008.
