| Home > Help Needed / General Tech Chat > Thermostat and electric pump | |||||||
15th Jan, 2008 at 11:09:23am
Is it possible to run both of them together? From reading other threads most people running an electric pump don't bother with a thermostat, is this becuse the pump can be switched on and off or is this due to back pressure problems?
15th Jan, 2008 at 11:29:10am
run a thermostat |
520 Posts Member #: 2093 Post Whore Grenoble, France |
15th Jan, 2008 at 01:58:58pm
You should not run without any pump pressure because this creates air pockets in the engine. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
15th Jan, 2008 at 02:43:41pm
I ran without a stat when i had my electric pump, as i has a control box for it. If you do remove the stat be sure to use one of the blanking sleeves in its place. |
15th Jan, 2008 at 03:33:56pm
None of the miglia / seven run a blanking sleve and all run electric pumps. On 15th May, 2009 TurboDave said:
15th Jan, 2008 at 04:26:24pm
Sod it..ive found an 83 degree one on ebay, i'll probably use that with a shite load of holes drilled in it!
15th Jan, 2008 at 06:51:29pm
On 15th Jan, 2008 Jimster said:
None of the miglia / seven run a blanking sleve and all run electric pumps. I was always told you needed one, but i guess not ? lol. On 15th Jan, 2008 matty said:
Sod it..ive found an 83 degree one on ebay, i'll probably use that with a shite load of holes drilled in it! Phil what pump were you using? I used one from a company called Corley conversions. |
15th Jan, 2008 at 07:58:44pm
None of the miglia / seven run a blanking sleve and all run electric pumps. But dont they also run dry deck? On 26th Oct, 2004 TurboDave16v said:
15th Jan, 2008 at 10:52:28pm
only a few of them, I'd say around 50% dry deck there engines On 15th May, 2009 TurboDave said:
16th Jan, 2008 at 12:39:40am
Hmm
203 Posts Member #: 479 Senior Member |
16th Jan, 2008 at 11:34:29am
We dont use thermostats at all, no difference if dry decked or not. |
16th Jan, 2008 at 12:30:36pm
Tim, you might want to point out your talking about the mig's since a lot of people wont know who you are |
16th Jan, 2008 at 01:12:37pm
for those who don't know, Tim is part of a team who Miglia's and Seven's Always along side sheepspeed in the padock and the bar On 15th May, 2009 TurboDave said:
16th Jan, 2008 at 01:52:26pm
Ah sorry, Yeah i crew for Rightline Motorsport, currently look after 1 miglia and 2 Se7ens, but i'm always helping out others.
16th Jan, 2008 at 06:02:07pm
On 16th Jan, 2008 Timinichelsea said:
We dont use thermostats at all, no difference if dry decked or not. Coolio
Does that mean you dont run a blanking sleave either? On 26th Oct, 2004 TurboDave16v said:
17th Jan, 2008 at 10:07:32am
no we dont use a blanking sleeve. |
