| Home > Help Needed / General Tech Chat > Installing Bike Speedo - Couple quickies! | |||||||
![]() 189 Posts Member #: 1774 Advanced Member Sydney AUS |
16th Jan, 2008 at 05:37:36am
Hi Guys,
Edited by pristic on 16th Jan, 2008. 1132cc Turbo ~120 bananas ATW - Fun Fun Fun
16th Jan, 2008 at 08:29:05am
I tried mine on the pot joint, and anything over 40 mph it stoppped working... Im guessing the pulse time was just to shoort for the sensor to quantify..
![]() 168 Posts Member #: 1772 Advanced Member Leicestersheershire |
16th Jan, 2008 at 09:06:21am
When I did this, I took the guts out of an old speedo, mounted it in a box and stuck the magnets on that. This meant that it was hidden away under the dash and was a quick install too. And if a magnet falls off, then you don't loose them! Tim Rowe
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
16th Jan, 2008 at 08:30:50pm
Rear hub gets my vote.
Back once again like a renegade master |
16th Jan, 2008 at 09:09:47pm
thats the one that comes with the acewell speedo |
16th Jan, 2008 at 09:50:20pm
Go for the Hub. I put mine on the driveshaft temporarily and athough it worked its more reliable in the hub and easy to fit. |
16th Jan, 2008 at 10:26:39pm
Ok, convinced. Ill use the drum like in the pic!
16th Jan, 2008 at 10:31:04pm
Should do, Its just a pulse at the end of the day. Back once again like a renegade master |
16th Jan, 2008 at 11:14:21pm
yes, any magnet will do as long as its strong enough.
16th Jan, 2008 at 11:19:30pm
http://cgi.ebay.co.uk/ACEWELL-M6-x-1-x-7mm...7QQcmdZViewItem Isambard Kingdom Brunel said:
17th Jan, 2008 at 01:41:07am
Thanks Kindly 1132cc Turbo ~120 bananas ATW - Fun Fun Fun
17th Jan, 2008 at 02:31:19pm
well spotted! |
17th Jan, 2008 at 02:37:08pm
Mini Mad, what dimensions did you program into the Acewell?? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
17th Jan, 2008 at 07:52:24pm
I dont know.
17th Jan, 2008 at 07:53:29pm
i'm just going to chalk it out and then dial it in using a gps. its only an estimate |
17th Jan, 2008 at 07:56:33pm
youll never get it bang on measuring it. There too much variation with the size of the magnet and the size of the pick up.
17th Jan, 2008 at 08:03:09pm
what does that matter?
17th Jan, 2008 at 08:19:15pm
What a Nugget Edited by Jordan on 17th Jan, 2008. Back once again like a renegade master |
17th Jan, 2008 at 08:42:02pm
the radius is from the hub centre to the edge of the tyre.
Edited by iain on 17th Jan, 2008. |
