| Home > Wanted > Lightened pre verto flywheel | |||||||
![]() 300 Posts Member #: 1746 Senior Member Kent |
17th Jan, 2008 at 12:50:47am
Im after a Lightened pre verto flywheel. i would ideally like an ultralight one, but i would consider anything non standard.
17th Jan, 2008 at 01:07:50am
If you are willing to wait a week or so, I will have one available, only about 3k on it from new, and most probibly with a few chips out the teeth on the ring gear. Other than that, it works a treat. I havent had any issues with the chipped teeth, and is common on the thin inertia starter ring gears.
17th Jan, 2008 at 03:57:44pm
I will probably take that off your hands if i havent sorted one by then. Is there any change you including the other bits?
28th Jan, 2008 at 08:07:23pm
BUMP
7th Feb, 2008 at 08:32:29pm
Here you go mate
