| Home > Help Needed / General Tech Chat > big end bearings | |||||||
![]() 213 Posts Member #: 249 Senior Member |
5th Jul, 2004 at 09:01:32pm
does anyone know... when assembling the big ends are the tabs on the bearings both together or on opposite sides??? |
62 Posts Member #: 198 Advanced Member |
5th Jul, 2004 at 10:14:16pm
Both together if i remember correctly |
5th Jul, 2004 at 10:17:04pm
im 99.99 sure it is but getting paranoid as i havent built a mini engine since college a very long time ago....that is how i took them out and stored them but my cosworth was opposite sides |
5th Jul, 2004 at 10:28:18pm
i put mine together last week an the tabs were on the same side as each other
6th Jul, 2004 at 12:33:16am
tabs same side.. but you realy should have marked what caps for what rods and there orientation when dismantling. turbo 16v k-series 11.9@118.9 :)
6th Jul, 2004 at 08:27:33am
tabs same side...
AlexF |
6th Jul, 2004 at 04:33:30pm
On 06/07/2004 08:27:33 AlexF2003 said:
tabs same side... if you want to check you should be able to see some slight "witness marks" on the con rod. Alex yes noticed them alex but im getting paranoid and double checking everything
i was the same with my cossie engine build but that was a good engine,just paranioia setting in! regards mark |
6th Jul, 2004 at 05:26:18pm
LOL
AlexF |
6th Jul, 2004 at 05:29:10pm
On 06/07/2004 17:26:18 AlexF2003 said:
LOL the A-series is a good engine too!!! Very strong design and even the head design hjas its advantages!!! If you wanna hand, just ask, I'm only up the road :) alex cheers alex....what i meant was the cossie engine turned out good! not that the a series isnt as good
all i need to know now is which way the omega writing in piston dish faces just to double check regards mark |
