| Home > Help Needed / General Tech Chat > Brakes and 10" wheels | |||||||
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
19th Jan, 2008 at 09:22:53pm
If I were to fit late type hubs (8.4" disc type) to my 72 clubman, and 7.9"discs and the appropriate callipers, would the wheels fit inside the wings, without fitting aftermarket arches? I want to have the chrome sill strip and nothing more, as I'm going for a standard look.
Edited by Leonard on 19th Jan, 2008.
19th Jan, 2008 at 09:46:24pm
165 tyres would be too much for 3.5J rims
On 5th Sep, 2011 Vegard said:
19th Jan, 2008 at 09:48:03pm
thanks scruffy
19th Jan, 2008 at 10:21:25pm
165/70's on 4.5j wheels may need an inner tube, not 100% sure though Drives
20th Jan, 2008 at 06:27:17pm
165s are the right size for 4.5J rims no inner tube required
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
20th Jan, 2008 at 11:21:41pm
I've got 165/70/10 A008s on 4½" Minilites with no inner tubes and I don't need arches - it'd be even better if I had disc spaced wheels instead of drum, but that's the penalty for upgrading the brakes... Metric is for people who can't do fractions. |
21st Jan, 2008 at 07:38:27am
Yeah the "cooper offset" minilites or the 4.5 inch will fit under the arches with discs. On 7th Nov, 2008 Nic said:
21st Jan, 2008 at 06:36:46pm
thanks. next question is, has anyone got any cooper s offset steel wheels for sale?
21st Jan, 2008 at 07:19:17pm
Proper s wheels are $$$. Reverse aren't but your back to square one as they are an inch more offest. Plus clearance behind reverse rims for brakes is very limited. 4.5 inch minilites are the only option on the cheap. I have S discs and 1" spacered drums on the rear with reverse rims and no arches but just a delux strip. They are out a tiny bit but I passed MOT 5 times before someone pulled me on it. On 7th Nov, 2008 Nic said:
