Home > Help Needed / General Tech Chat > Triple or single groove valves ?
Is there any advantage in one over the other on a single or triple groove valve/collet ?
I did notice when i rebuilt a friends 1380 engine that the triple groove valves had worn really heavily/very thin around the collet area, so is the single better ?
Phil. :)
isnt something to with the spring lbs's? more suface area on 3 groves?
Engineering judgment wold tell me 3 grooves are better. Never had problems with either.
I just chose the valves I wanted based on size/availability/design/flow/quality etc, didn't even consider the grooves.
Des Hammil didnt like triple groove collets
Supposedly, the three grooved typs is considered weaker. I have no idea why. If you're not revving 10000rpm all the time, I wouldn't care at all.
Subarus and LSx engines all use single groove that clamp the valve.
I know my LSx runs about 150lbs seat pressure. Stem is same diam as a Mini valve ( I had 2 ex valves sitting beside each other the other day lol )
The Mini one is so tiny
according to most gurus the triple groved ones part company in VERY high reving motors
theres no issues with the single groved ones
gialoflys motor runs triple groved ones with no issues todate though
phil
i must agree that they are prone to more wear on the collets
i personally have never seen any problems with them parting and i have stripped hundreds of standard! heads
i think the main reason is high spring pressures and massive cam lifts with 1.5 rockers on on N/A race motors which kills them
not realy an issue with turbo motors
That's pretty much what i was thinking.
It was a friends 1380, 286 cam, 1.5 rockers, big valve head etc which had serious wear issues on the triple collets. But he did rev it very hard.
I guess either will do for most Turbo applications then.
Cheers guys
Phil. :)
ZDDP Oil issues, are a contributing factor phil
you will know this, stick with it buddy *wink*
Minispares north have MASS collets on stock cheap *wink*
Edited by BENROSS on 21st Jan, 2008.
