| Home > Help Needed / General Tech Chat > plea for gearboxpics/help | |||||||
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
21st Jan, 2008 at 10:37:02pm
well i've done the 1st bit & refurbed my mainshaft gearset with new bearings, detent springs etc etc, put it in the box & 1st gear seems really loose, i've looked at mr fentons gearbox pics & dont seeany differances to mine, what goes between the 1st gear & casing centre web? does the laygear stop it moving around, i'm taking it apart & re-checking all 2moro
21st Jan, 2008 at 10:52:49pm
get a metro haynes, its all in there bud "Turbo's make torque, and torque makes fun"
22nd Jan, 2008 at 12:16:47am
This helped me..
![]() 214 Posts Member #: 1574 Senior Member Malta |
22nd Jan, 2008 at 11:45:50am
I've been rebuilding mine just recently and have also used the miniforum link. My metro Haynes is not at all detailed so I guess the later copies have been edited.
22nd Jan, 2008 at 11:51:26am
ah yeah its the ones with the red cover that has the gearbox greakdown in "Turbo's make torque, and torque makes fun"
22nd Jan, 2008 at 12:34:04pm
Hi, i have a fully built one out of the engine that you can come and view take some pics, notes etc if that helps?
Edited by MarkGTT on 22nd Jan, 2008. |
22nd Jan, 2008 at 02:25:01pm
have you rpelaced the 3rd motion shaft roller bearing? "Turbo's make torque, and torque makes fun"
22nd Jan, 2008 at 03:01:25pm
Strange, what sort of "loose" ? end float or "wobble" ?
22nd Jan, 2008 at 05:00:24pm
the shim & needle roller bearing are pushed in home, 1st/2nd syncho/1st gear over the top, the bearings are all new, the gap between the 1st gear & casing is the same as in the pic above, but......it can be pushed & touches the casing obviously not good to run that way, i would'nt!!!!
Edited by clubminiflip on 22nd Jan, 2008. SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
22nd Jan, 2008 at 05:09:51pm
In my picture above, there is no way the 1st gear will move towards the casing web !!!
22nd Jan, 2008 at 05:43:36pm
Sorry for crap photo colouring but,
22nd Jan, 2008 at 05:59:58pm
Looks like you did your edit before I posted the second photo but, yes, sounds like the sleeve/collar isn't being trapped by the bearing.
Edited by Rod S on 22nd Jan, 2008. Schrödinger's cat - so which one am I ??? |
22nd Jan, 2008 at 06:23:12pm
the the outer part of the 1st gear can touch the outer race of the 3rd motion bearing there is def something amiss, have you tried the old 3rd motion bearing to see if that is the problem?
