| Home > Help Needed / General Tech Chat > Ideal piston clearance ??? | |||||||
22nd Jan, 2008 at 01:04:04pm
As above really, for 1360 (Using the 73.0mm pistons from MiniSport Australia) and say max 8-10psi boost (just for road use) and CR 8.3 or less (depending on how much I can safely machine out of the pistons, yet to be determined, and how much I can take out of the head).
22nd Jan, 2008 at 01:52:51pm
I use 0.006mm on must stuff. That's the upper side of what you're quoted. Seems to work.. On 13th Jul, 2012 Ben H said:
22nd Jan, 2008 at 03:22:06pm
Go for the maxim stated i.e. 2.5thou".
