Home > Help Needed / General Tech Chat > Gear Box Help plzzzzz!!
Markie_D
Member #: 1660
Formally Mini_Uk
London
After the gear box was rebuilt, it went into gear fine. ive connected the rod to the box, clevis pin in, clutch bleed etc.
But i cant select any any gears *frown*
Really hope it something simple ive done wrong..
Any help would be great :)
Cheers lads.. :)
Shit Happen's
Markie_D
Member #: 1660
Formally Mini_Uk
London
This is an old pic before it was put it.. Should it be this way round, as ive just looked and ive got it the other way round ?
Could this be the problem.
Cheers.. *blush*
Shit Happen's
yes should be as in the pic.
Markie_D
Member #: 1660
Formally Mini_Uk
London
Lol Noob i am... should of checked that.
So i hope that sorts it..
Another thing. im now trying to get the clevis pin thing out again, and my brother said the pin only comes out one way, this correct ? as before a pain to get out, with not alot of room to bash it out..
U live and learn.
Cheers m8
Shit Happen's
Markie_D
Member #: 1660
Formally Mini_Uk
London
Sorry, ive turned it round, but still wont Select gear ???
Doe's the gearbox have to be in a gear etc before you place the rod back on ?
:( helpppp ...............
Shit Happen's
Markie_D
Member #: 1660
Formally Mini_Uk
London
me again ...
Hoggy need ya help mate *wink*
I got 1st gear 2nd and reverse...
had to push it in gear hard at first, but all smooth now. but cant get 3rd or 4th :(
it had new bulk rings etc. so maybe there even stiffer ?
Will it free it when im all set to drive it ?
Edited by Markie_D on 22nd Jan, 2008.
Shit Happen's
Star Mag
Member #: 375
Leicestershire
Mine was slighty stiff after a rebuild was the forks that the bell crank lever runs in I think its called, The bits that move the selectors. i took them out cleaned them up with a file to remove the burrs and put them back in! seemed to sort it. Also i used lots of gearoil when building the box up especially on the baulk rings as thay were tending to stick to the gears when torqing up the shafts!
Markie_D
Member #: 1660
Formally Mini_Uk
London
Bugger taking the engine out again. lol.
I remember it being little stiff when i tried the gears with the box out, but once they were in gear all was out.. looks like i have same problem with 3rd and 4th gear.
so hoping when i drive back and forth, it frees it self ??
Shit Happen's
i wouldnt drive it as if it is something more serious than it just needing to free up such as something has fallen in/gone in wrong and jammed it up then it could mean another more expensive rebuild!
Markie_D
Member #: 1660
Formally Mini_Uk
London
just driving a little forword will damage something ??
I called the guy who checked my box about it, and he said just drive little forward to move the gears around, and that should help free it .. hmm ?
cant really see anything falling off ..
it was tight at first with box out after just rebuilt, and once in the gears, it lossend up... it's has happend again, freed 1st, and freed 2nd. but just not 3rd and 4th as u know.
So hopfuly the main man richard could tell me his magic *wink*
Shit Happen's
turbo hogster
Member #: 178
stowmaket suffolk
well are you trying with engine running or stopped, if it selects in all gears with engine stopped but not when engine running then check your clutch throw.
also have you any oil in the gear box if it hasnt got to the engine running stage, as this will help no end, but should go into to gear nice and easy but may be a bit notchy at first if you have fitted new baulk rings.
Markie_D
Member #: 1660
Formally Mini_Uk
London
Also have you any oil in the gear box if it hasnt got to the engine running stage, as this will help no end, but should go into to gear nice and easy but may be a bit notchy at first if you have fitted new baulk rings.
Havn't started it yet, im getting to that stage :)
I just wanted to check it all the gears were working, as that was The one thing bugging me, hoping all was ok.
So ive been trying with engine not started.
Clutch throw looks like it's working.
Has oil inside.
have fitted new baulk also.
Ill get to the running stage, so i hope that will help select 3rd and 4th.
Ill let you know.
Thanks rich.
Shit Happen's
turbo hogster
Member #: 178
stowmaket suffolk
well you should be able to get all gears easily then with out engine running, if you cant get all gears with out it runing then dont start and then try as it may damage things.
try this, jack up one wheel , and in neutral spin wheel this will spin the main shaft and lub up the rings,
also unattach the gear change at the gear box and make sure the stick moves freely, whilst unattached you should be able move the selector rod clock wise and anti clockwise whilst in neutral.
Markie_D
Member #: 1660
Formally Mini_Uk
London
Hello rich..
Ive taking the rod away from the selector rod. and that is ok whiles moving clock wise and anti clockwise in neutral.
Ill try the wheel spining part once ive finished putting the discs back on.
making me well nervous lol
Shit Happen's
turbo hogster
Member #: 178
stowmaket suffolk
just a query did you remove the bell crank levers when you stripped the box down mate.
Markie_D
Member #: 1660
Formally Mini_Uk
London
Yes i did mate, striped the whole lot out..
It was little tight going into gear like i said after the build, but once in gear, it was alot easyer. that was when the box wasn't on the engine of course, as we had to check all was working ok.
once the nuts were tightend up either end, we checked again, and gears were tight again, but managed to get into the gears in the end. everything is new, bulk rings, bearings etc.
So im hoping it's the bulkrings that need some oil round them to free it.
The guy who checked the box, said it will go into gear alot easyer when the oil goe's in, and the oil gets warm after starting ??
im near to the stage of finishing the car, so ill try jacking 1 of the wheels up and spinning it like u said. i hope that helps.
so would it really damage the gears just by starting the engine, as few ppl have said the samething, start the engine will help,
but not driving it of course. maybe the heat will unstick it?..
it be a kick in the nuts if the engine has to come out again.
dont think i could cope with that. *frown*
shame ya not closer to were i am.. the cars in kent being done.
think i need a drink lol stress free BEER *happy*
what u reacon my chances r rich.
you ever come across this before ?
Shit Happen's
Markie_D
Member #: 1660
Formally Mini_Uk
London
I should of used some oil on the bulkrings while i was building it.
mine got sticky again once toqued up..
Shit Happen's
has oil helped?
is it sorted now then?
Markie_D
Member #: 1660
Formally Mini_Uk
London
No jo mate :(
Still gonna try the wheel things..
Edited by Markie_D on 24th Jan, 2008.
Shit Happen's
First,
When you say "It was little tight going into gear like i said after the build, but once in gear, it was alot easyer." what do you mean ??? What was "a lot easier"? The selector ?? Turning the shafts ?? Or what ??
New baulk rings installed with no lubrication can certainly cause drag between input/lay/output shaft if that's what you're trying to turn, but should not cause too much of a problem selecting any gear in a STATIONARY gearbox.
So, if it's turning the shafts that is stiff (irrespective of which gear is selected) I would look to the baulk rings or any other part of the bearings etc. being wrongly assembled, BUT, if it's the selection that is stiff, and you had the bell cranks apart, I wonder if the "claws" between the bell cranks and selector shaft forks have gone back together right.
It is very easy, when disengaging the interlock mechanism (in order to lock the gears to undo the big nuts) for one of the claws to drop out of the bell cranks so leaving the selector rods in the wrong position when you re-assemble.
Hard to explain without a photo (I may have one somewhere) but could explain a selector stiffness problem, rather than an input/output shaft stiffness problem.
Hope that makes sense.
Rod.
turbo hogster
Member #: 178
stowmaket suffolk
well mate its not looking good, you should always use plenty of oil on thew baulk rings as the can drag on the gear cones causing the box to lock up.
but i have never had a problem, as retired said you shouldnt have no problem getting into gear on a stationary engine, somthing not right some were.
but get her started and see if she free up a bit.
but dont try and put her into gear whilst the engine running, turn her off then try.
have you filled the engine with oil yet?
Markie_D
Member #: 1660
Formally Mini_Uk
London
Yes mate.:)
Right then, rich need ya help buddie. or whoever can help please.
After trying to find out why the car wouldn't turn over, which is Now sorted :)
The car is on Axles. we turned the key over, but there is me thinking it's in neutral, but the bloody wheels turn :(
Put cluch in and it stops, so clutch seems fine.
Has the rod coming from the gear change been fixed onto the little rod coming from the gearbox while in gear ?
well confussed now.
by the way, i fitted a kad short shift.
I know not everyone's cup of tea, but if i dont like it ill sell it.
could that be problem. etc/
Be greatful for ya help/
Shit Happen's
