Home > Help Needed / General Tech Chat > 1.5 roller tip rockers
1310turbo
Member #: 41
just got some from minispares. awapped a few things over from the old rockers such as the clips and washers and the springs inbetween the rockers. went to put them on the new heard and they dont aligh up. the mouting holes do, but when they are all located the tips dont alight up with the top of the valve stem. anyone else had this problem with the 1.5's? and what you did to sort it. im thinking about loosening the grub screw and moving them around but i cant see that solving it.
A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white|
FesterTurbo
Member #: 18
For the cost of the things I'd consider calling MiniSpares.
Just fitted 1.5 full Roller tips to mine and only had an issue with the head bolts. MiniSport failed to mention you need slimmer ones. Alignment seems fine though.
