| Home > Help Needed / General Tech Chat > Wet Manifold Supercharger, Charge Cooler | |||||||
![]() 6 Posts Member #: 2218 Junior Member Eastbourne |
24th Jan, 2008 at 02:42:11pm
Hi folks
Edited by mininutter-edmc on 24th Jan, 2008. www.edmc.co.uk
24th Jan, 2008 at 02:54:31pm
fuel will definately condense and fall out ,it will get less at high speed but definately not good .you will be getting some cooling effect running the fuel through the charger anyway.
24th Jan, 2008 at 03:20:32pm
I thought that would be the issue. But even with the fuel going through the charger, its too hot for my liking.
www.edmc.co.uk
![]() 56 Posts Member #: 1901 Advanced Member Bolton |
24th Jan, 2008 at 03:35:43pm
What does Stuart's charge cooler consist of? His website says he is offering them for all conversions.
24th Jan, 2008 at 04:12:55pm
I just realized you said chargecooler meaning water to air ! i was imagining a cooler at the front so the fuel would have to make a long trip ,.
Edited by robert on 24th Jan, 2008. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
24th Jan, 2008 at 04:25:22pm
On 24th Jan, 2008 captain_cabinet said:
What does Stuart's charge cooler consist of? His website says he is offering them for all conversions. Chris Stuart gave up with a water/air matrix. I heard the solder melted creating a water injection system. So thats not avalaible. :( He's now got a saddle tank which sits over the charger and cools the casing. The water is cooled at a small rad at the front. He's seen good results from it and I'll be having it too. On 24th Jan, 2008 robert said:
I just realized you said chargecooler meaning water to air ! i was imagining a cooler at the front so the fuel would have to make a long trip ,. with the cooler at the supercharger to head face area , i would think that , if it triggered water flow to the cooler only under boost, with a boost switch at say 1 psi , you could deff make that work . on a really cold day ,with the water going through a rad at the front and then to the charge cooler, i could imagine a prob where the tickover may be a bit iffy , but if you control that flow it would be ok i would have thought . Thats my plan, water/air and a pump switched from the Emerald ECU. Thinking I'll try it with a spare engine and wait for a bang
www.edmc.co.uk
