| Home > Help Needed / General Tech Chat > omega piston help | |||||||
![]() 213 Posts Member #: 249 Senior Member |
6th Jul, 2004 at 04:39:32pm
paranoia is setting in again!!! i noticed in the rover manual that the pistons on the turbo have a offset gudgeon pin....on my omegas there is no markings for the front and also no noticeable offset .....i phoned omega for info on which way round to fit them and they said that the piston should have no offset pin but a offset dish which points to the front of car,but it hasnt.....help!!! looking from front of car should the 'omega' writing in dish be right way up or upside down Edited by mark4765 on 6th Jul, 2004. |
6th Jul, 2004 at 04:40:32pm
:cool: Edited by mark4765 on 6th Jul, 2004. |
6th Jul, 2004 at 05:13:25pm
I assume they mean the piston dish should be under the spark plug...
AlexF |
6th Jul, 2004 at 05:33:39pm
On 06/07/2004 17:13:25 AlexF2003 said:
I assume they mean the piston dish should be under the spark plug... That would also follow std piston design ideas too... Alex the dish is central alex and there doesnt seem to be any offset on the gudgeon pin so in theory it doesnt matter which way round they go...i had photos of the engine which i took while stripping for inspection but they have disapeered,hence the problems/paranoia! i want to build this engine right and once only mark |
62 Posts Member #: 198 Advanced Member |
6th Jul, 2004 at 10:41:13pm
I believe the writing stamped on the top should be the right way up when viewed from the front, I had Minisport fit the pistons to the rods, and as the rods were all stamped 1,2,3,4 etc they put them on the right way.
6th Jul, 2004 at 10:46:26pm
Try get hold of Jukka, i think he used omega pistons Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
7th Jul, 2004 at 06:08:31am
AS far as I remember there were never 1275 pistons with offset piston pins. Standard factory pistons may or may no have FRONT or A marking that should face the front of the engine. Replacement pistons and latest Hepolite pistons (IIRC) don?t have these.
