Home > Help Needed / General Tech Chat > Turbo oil seals
calum_lorimer
Member #: 318
Edinburgh
looking at buying a mini with a turbo engine, i've been told it's a bit smokey and that the turbo oil seals are to blame. does this sound right? how hard are they to replace?
Thanks a lot
Calum
speedster turbo
Member #: 244
turbo rebuild kit is about ?50 from Turbo Dave on here, smiking doesn't always mean turbo, look at some of the past posts on here, it could be anything from worn bores/rings to stem seals or just needing the correct grade of oil
Speedster turbo under construction
calum_lorimer
Member #: 318
Edinburgh
ye, i'm a bit unsure of how the guys come to the conclusion that it's the turbo seals. Is a turbo rebuild a hard thing to do, i've done things like cam changes but i've never even set eyes on a turbo.
Thanks
Calum
If you see it running at tickover, lift the rocker cap and see how many fumes are coming from there. If just a few wisps, that's ok, but a fair amount of vapours does suggest a goosed engine...
Prob best you get a re-conditioned turbo methinks...
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
A rebuild kit is from Iain not TD :)
But unless you are very happy with stripping and rebuilding turbos I would suggest getting a recon turbo.
Alex
AlexF
Yep, i do the rebuild kits. Mine seems ok so far, havent really tested it though. Its quite simple really, just be careful with the balance thing.
I thought that i may aswell give it a go. No harm done!
If it doesnt work then it should be a cheaper rebuild as the hardest bit is getting everything apart when its been running hot for so long.
calum_lorimer
Member #: 318
Edinburgh
he does say it's only very slightly smoky, i've not seen the car yet though, just wanting to check what i might be getting into.
how expensive would a recon turbo be? roughly?
Thanks
Calum
clubman_dan
Member #: 142
Winchester
their something like ?350 from turbo technics i think
DAN :)
and about ?200+ from AET for just bearings and seals.
