Home > Help Needed / General Tech Chat > quick question
Leonard
Member #: 806
Cirencester, Gloucestershire
Is there any reason, apart from the bracket on the front of the block, why a dynamo can't be fitted to an a+ engine?
cheers, Tom
only the wiring, but thats the car not the block
it will bolt up to the water pump ok, and you'd need to support the rear of the dynamo some how.
Leonard
Member #: 806
thanks. its an a+ going into a 1972 car, so wiring should be ok. i should be able to make a bracket for the far end of the dynamo
