Home > Help Needed / General Tech Chat > Clutch & Flywheel help............again
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Had flywheel & backplate resurfaced as the clutch plate made abit of a mess. Asked before about the measurement between the backplate lug & face of the backplate. Realised that because the flywheel has been machined as well, this must also alter the lug length. Also what size spacers for the straps?
Hopefully the pics will explain abit better than my typing.
Thanks to Andy Waller for clutch plate :)
Edit....Forgot to mention, using 3 sets of straps. Not sure if it makes a difference.
Edited by Jason G on 25th Mar, 2008.
On 19th Jan, 2010 wil_h said:
i have always set my lug height to 1" and the flywheel thickness to 7/8".
i took these dims off an old unmolested two piece f/wheel.you would i deally need to deduct the thickness of the 3rd strap off the backplate lug height.
use 10 mm spacers for a starting point and see if the straps look anything like level,
carl
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Had alook at Andy's flywheel assembly he got from MED. Was fitted with the thicker road/rally style AP clutch plate. The straps were not straight.
Had a measure up..lug height is 25.3 near as damn it an inch...flywheel thickness is 8.1mm. Can't do imperial measurements!
Cheers Carl *wink*
its the thickness from the friction face to the ring the diaphram acts upon,
the straps dont have to be cock on level,just reaqsonably near will get the job done,
23.5mm lug height if using a grey for optimal results....
Jason G
Member #: 1459
En-suite user
Braintree, Essex
cheers carl...owe ya a beer at MITP*wink*
lol
Edit...don't complicate things Dave!!!!!!!!!!! :)
Edited by Jason G on 28th Jan, 2008.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
BTW...any idea of make of flywheel?
this will depend on plate used though surely Dave,
flywheel looks like an old ST from yesteryear,lol
l
Jason G
Member #: 1459
En-suite user
Braintree, Essex
its an old car Carl!!!!!!!
Good or bad...it weighs 3.8kgs
well you wont find one in my clutch housing,
but it'll do,
redwing
Member #: 1574
Malta
I recently had my backplate machined to 23.5mm as Turbo Dave and Benross suggested in other posts, fitted with two straps and a grey diaghram and it assembled perfectly. Not tried in anger yet though.
