Home > Help Needed / General Tech Chat > dump valve
sauber 200
Member #: 245
do you need a sandwich plate on the manifold or can you t piece
it intolink pipe from carb to manifold,
cheers
just put it either on the servo take off or another tapping on the inlet manifold.
stevenford_uk
Member #: 144
i am going off that sticky up noddle on the inlet manifold that the brake servo goes off.
jamesfawcett
Member #: 218
Bingley, West Yorkshire
I used that one too stevenford. I used the top outlet for my boost guage, and the side one (servo) for my dump valve as i have no servo.
stevenford_uk
Member #: 144
i have a servo, so ive used the servo one for me servo and im using the top one for my dump valve, im using the t piece on the actuator for my boost guage. call me steve.
Boost gauge wants to come off the manifold so that you know what boost the engine is seeing, thats the most important bit. *smiley*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I agree with iain although mine is still running off the AR unit tapping at the carb.
Alex
AlexF
that is just about as good though as its after the butterfly.
sauber 200
Member #: 245
sorted, just off to join the bus drivers union lol
stevenford_uk
Member #: 144
oh, ok then, ill run my bleed valve off that pipe then and tee into my manifold for the boost guage
