Home > Wanted > 2.9 crownwheel and pinion
As above, or would consider any of the ratios (numerically) less than 3.44 if the price was right.
Kicked myself for missing one on eBay last weekend....
Rod.
minix
Member #: 2236
Hi, may have one if you still need it not sure on the ratio, std turbo will check if you are intrested.
Coupe
Member #: 2178
Leyland, Lancs
Standard turbo should be 3.2 I believe.
Hi minix...
I'm interested, std Metro turbo should be 3.2 as Coupe says but, at the moment, I'm after anything less than 3.4 if the price is right !!!
Rod.
minix
Member #: 2236
Hi, ok I'll check @ the week end, send me a PM with your details & i'll let you know what I have got
